Hello people, I am trying to #clip raster by polygon to determine the area of the raster image within the shapefile area using ArcGIS 10.2.2. But the clipping is failing. I am using the Clip (Data Management) tool. Both the raster image and the shapefile polygon is in BTM (Bangladesh Transverse Mercator) projection system. I am keeping the "Use input features for clipping geometry" box checked and "Maintain clipping extent" box unchecked. I followed the same procedure for 15 other files which worked out fine. I am attaching the raster image and the shapefile hereby. I would be obliged if someone could help me over here. Thanks in advance.
Close all ArcGIS Desktop applications. Open a new/blank ArcMap session.
Add the raster and polygon to the AcMap.
Run the tool (Also save the output Raster to a smaller pathname, not in the default.gdb; Also NO space and use underscore instead of any special character)
e.g. \Project\Data_2011.gdb\Jamuna_2011
Glad to help
And finally this works! Changing the default output location! I can't stop laughing Anyways, Dhonnobad (assuming from your name that you are a Bangali)!
Here they are.
Could you attach the screenshot of the tool with filled parameters (before running the tool)?
Thanks for you reply. Your output is exactly what I need, but it is failing even after turning off the background processing. The error message is like this-
Another tool would be Extract by Polygon—Help | ArcGIS for Desktop . Spatial Analyst extension required to run this tool.
I am able to clip the Raster using Clip (Data Management). Turn off the Background processing (Geoprocessing > Geoprocessing Options) and try again.
Here is what I got
Right now 10.4 version is not available for me. Is there any other way to do it in version 10.2.2?
in 10.4 the extent is now expected to be rectangular Clip—Help | ArcGIS for Desktop
why not try the equivalent in Clip—Help | ArcGIS for Desktop
