public partial class TestScrollViewer : UserControl { public TestScrollViewer() { InitializeComponent(); MyMap.Loaded += AttachMouseLeftButtonHandlers; // maybe set in XAML as well : Loaded="AttachMouseLeftButtonHandlers" } private void AttachMouseLeftButtonHandlers(object sender, RoutedEventArgs e) { Map map = sender as Map; // Get the "RootElement" of the map ~ of map.GetTemplateChild("RootElement") but GetTemplateChild is protected and Map is sealed var rootElement = ((FrameworkElement)VisualTreeHelper.GetChild(map, 0)).FindName("RootElement") as Grid; if (rootElement != null) { rootElement.MouseLeftButtonDown += RootElement_MouseLeftButtonDown; rootElement.MouseLeftButtonUp += (s, arg) => _upFired = true; } } // Hack to get the map taking care of the MouseLeftButtonDown event even if // this event is handled by the a parent element such as a scrollviewer private bool _upFired; void RootElement_MouseLeftButtonDown(object sender, MouseButtonEventArgs e) { _upFired = false; Dispatcher.BeginInvoke(() => { if (!_upFired) // else up event fired meanwhile e.Handled = false; }); } }
What do you mean? I just tested and I am able to view the live application and I am able to download the code and get the ScrollableMap.cs file.
<ScrollViewer Margin="0,8,8,8" BorderBrush="{x:Null}" HorizontalScrollBarVisibility="Auto" VerticalScrollBarVisibility="Auto"> <Grid x:Name="GridThatHoldsTheContent"/> </ScrollViewer>
<!-- ... --> <StackPanel Grid.Row="0" MaxHeight="1454" VerticalAlignment="Top" Margin="25,25,28,0"> <Border BorderThickness="1" BorderBrush="Black"> <Grid> <esri:Map x:Name="Mapa" VerticalAlignment="Top" WrapAround="True" Background="#FFC3D2E5" IsLogoVisible="False" Height="1187"> <i:Interaction.Triggers> <i:EventTrigger EventName="ExtentChanged"> <i:InvokeCommandAction Command="{Binding AcaoExtentChanged}" CommandParameter="{Binding ElementName=Mapa}"/> <ei:CallMethodAction MethodName="InvocaOMetodoDeHistoricosDoMapaNaViewModel" TargetObject="{Binding ElementName=PaginaRetratoA3}"/> <ei:CallMethodAction MethodName="ConfiguraExibicaoDeLegenda" TargetObject="{Binding ElementName=PaginaRetratoA3}"/> </i:EventTrigger> </i:Interaction.Triggers> </esri:Map> <esri:Navigation VerticalAlignment="Bottom" Margin="10,0,0,10" Background="#FF336397" Style="{StaticResource EstiloNavegadorImpressao}" Map="{Binding ElementName=Mapa}"/> </Grid> </Border> <!-- ... --> </StackPanel>
The sample didn't open...
Look at this sample. There is a hack at the end of ScrollableMap.cs (without any guarantee though)
