Hello all
I need t create a feature in a featureclass that has subtypes in Enterprise geodatabase with some other attributes.
Some of the attributes will be taken from the subtype default values and other will be taken from a value list.
As far as I understand, the way to create a feature with default subtype values is to use edit template (it looks like define subtype create edit template for each subtype automatically).
The only way I found to use it is to do editOperation.create(EditTemplate).
I have an option to add the geometry to the create method but no other attributes (if I am using template).
I need something like editOperation.Create(editTemplate, geometry, attribute dictionary)
The only way I found is to take the new record and use Inspector to update values.
Am I missing something?
