The select tool defaults to the rectangle select, I almost always would prefer the Lasso tool. There should be an option to set your default choice of selection in your projects.
Thank you!
Included in ArcGIS Pro 3.6!
The last active Select tool is now remembered and honored when closing/re-opening Pro.
Thanks all - really appreciate the discussion and openness to a creative solution.
Hope this helps!
-Nathan.
Working on this for Pro 3.6 (as per discussed above -- "remember the last mode of the Select tool").
Thanks again for the input and discussion!
Thanks @NathanShephard. Appreciate you looking into this. So many people I work with complain about it. 🙂
Hi @NathanShephard yes having Pro remember which select tool I was using last would also be effective. It would basically do the same thing for me as if there was a setting because I find I almost exclusively use the lasso Select.
Thank you for taking a look at this and seeing what you can do!
Thanks both! Will see what we can do. 🙂
@NathanShephard That's an ideal scenario for me
Thanks Michele! My apologies, my note wasn't clear.
Pro does NOT currently remember which Select tool you used last - it resets to Rectangle every time.
However, IF it did remember it, would that meet your need? (IE: rather than requiring a setting).
Thanks! Nathan.
Thanks for submitting this idea.
Rather than yet-another backstage configuration setting, how would you feel about having the active Select tool remembered over multiple Pro sessions?
So if you close Pro with Select by Lasso active, it would be the default select tool in your next Pro session.
I like the idea. It would be cool to set the default opening tool as well. It's always Explore, but we use Select much more often.
Ah I had searched for an existing Idea and didn't see anything! Not sure how I missed this. Thanks for the link!
you might want to jump on this idea tool
Set Default Select Tool in ArcGIS Pro - Esri Community
or perhaps the ideas can be consolidated
I would like to see the ability to set a default for the Select tool in the Selection section of Pro's settings. The rectangle is one of the least useful options in most of my use situations, so I always change to the lasso, but it would be great if that was just something I set once, and didn't have to do again (or at least until the next update).
Please at least make this an option in selection settings. It's very annoying every time I start a new ArcPro session I start to draw a selection area and need the lasso, not the rectangle.
Agree
The Select tool always resets to "Select by Rectangle", which is not useful for my purposes. I always switch to Select by Lasso. I would like to be able to make this my default select option in Pro, or even making it defaulted to a specific project file.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
