I has searched in the community, many guys have this requirements but no answer.
The context is as the screenshot attached.
Typically, you can manage multiple pop-ups by manually setting their content and ensuring they open at different locations.
require([ "esri/Map", "esri/views/MapView", "esri/Graphic", "esri/PopupTemplate", "esri/layers/GraphicsLayer" ], function (Map, MapView, Graphic, PopupTemplate, GraphicsLayer) { // Create the map const map = new Map({ basemap: "streets-navigation-vector" }); // Create the MapView const view = new MapView({ container: "viewDiv", map: map }); // Create a GraphicsLayer to hold the graphics (popups) const graphicsLayer = new GraphicsLayer(); map.add(graphicsLayer); // Define a simple popup template for each graphic const popupTemplate = new PopupTemplate({ title: "{name}", content: "<b>Value:</b> {value}" }); // Sample data (could come from a database or API) const data = [ { id: 1, name: "108", value: "36.5", coordinates: [-118.15, 33.76] }, { id: 2, name: "106.1", value: "33.7", coordinates: [-118.17, 33.77] }, { id: 3, name: "108.2", value: "35.9", coordinates: [-118.16, 33.75] } ]; // Loop through data and create graphics data.forEach((point) => { const pointGraphic = new Graphic({ geometry: { type: "point", // Create point geometry longitude: point.coordinates[0], latitude: point.coordinates[1] }, symbol: { type: "simple-marker", color: "blue", size: "8px" }, attributes: { name: point.name, value: point.value }, popupTemplate: popupTemplate // Apply the popup template }); // Add the graphic to the graphics layer graphicsLayer.add(pointGraphic); }); // Optional: Set view to zoom in to a specific area if needed view.goTo({ center: [-118.16, 33.75], zoom: 14 }); });
Hi nafizpervez:
As the code above,the popup only open when it is clicked. Any method to open all the popups of graphics?
