Please add date and time format as dd.mm.yyyy hh:mm:ss to Enterprise apps and map viewer. It is preffered date format for lot of coutries. https://en.wikipedia.org/wiki/List_of_date_formats_by_country
Another solution would be to add the possibility to specify custom date format in map viewer and the format is then used in all the apps and widgets the map is used. Currently Experience Builder table widget does not honor the date format specified in map viewer.
By dd.mm.yyy hh:mm:ss did you really mean dd.mm.yyyy hh:mm:ss?I see no instances of a 3 digit year in use on the wiki site.
Yes, fixed my post.
The date/time format in the Experience Builder table widget should adapt based on the language/region settings. Could you specify the language/region in question, and provide the actual date/time displayed on the table widget for your rejoin?
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
