I'm working on a project for school where I need to recreate a coloroized LiDAR point cloud and am using the Solution walk through. I have created the DEM, DSM, and nDSM but once I attempt to create buildings at the first step it fails after a few seconds and I cant figure out why. I think there may be a coding error that it keeps running into but I'm not sure how to soleve it.
Extract Roof Form
Tool Path
C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\CreateBuildings.tbx\ExtractRoofForm
Parameters
Buildings SEAFPnew
Elevation Surface (DSM) SEA16_dsm_surface
Ground Elevation Surface (DTM) SEA16_dtm_surface
Normalized Elevation Surface (nDSM) SEA16_ndsm_surface
Create Flat Roofs Only false
Minimum Flat Roof Area 250
Minimum Slope Roof Area 75
Minimum Roof Height 8
Output Building Polygons C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\3DBuildings.gdb\SEA_BLDG
Simplify Buildings true
Simplify Tolerance 0.1
layer1
first_time false
previous_layer SEAFPnew
first_time_dsm false
Messages
Start Time: Monday, December 16, 2024 3:05:19 AM
ArcGIS Pro version: 3.4
Project Home Directory is: C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions
Shapefiles are not supported. Please copy to a geodatabase.
Input data is not valid. Check your data.
Error on line 2393
Error in file name: C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\scripts\bm_common_lib.py
with error message: AttributeError: Object: Error in parsing arguments for Exists
Failed script Extract Roof Form...
Failed to execute (ExtractRoofForm).
Failed at Monday, December 16, 2024 3:05:21 AM (Elapsed Time: 2.42 seconds)
