Hello, i have a problem with missing verticies on polygon shared borders. Is there any tool to fix this for many features?
It can be done with integrate tool, but at first i didn't notice that the gap between polygons was larger than used tollerance. (Tollerance was set to 0,001 while gap was 0,003)
So no one approach will manage all cases... to be expected I suppose
I tried reapir geometry but it didn't solve the case. Dissolve with unsplit lines in cases like below:
Did something like this:
You didn't mention anything about topology... so I will leave that aside
You could try a...
Check Geometry
and if errors are found
Repair Geometry
or just try it on its own.
Alternately a
Dissolve
with an
Unsplit line
might make things go away
