Hi,I did try to export out the widget controller and try to customize it and hit with error.Anyone have similar experienced?
Is this the first time you've had this issue? Have you been able to do this successfully in the past?
Hi, you could try removing the LayoutItemToolbar. The component will render a context menu for some widgets(image, text, button) only in builder. Removint it won't affect other functionalities.
1st time hitting the issue
Make sense of the workaround. Thanks
