I am a little bit confused about the version numbering of the ArcGIS API for Python.
I am trying to run a python script I wrote and tested with Python 3.9.16, together with ArcGIS Pro 3.1.1.
When I run this code in a Notebook in ArcGIS Online, I receive these messages:
/tmp/ipykernel_23/3079746621.py:164: DeprecatedWarning: shared_with is deprecated as of 2.3.0 and has been removed in 3.0.0. Use `Item.sharing` instead.
print (item.shared_with)
But I think I found that the latest version of the ArcGIS API is 2.4, not 3.0. So I guess this is a forward looking statement, and I should read it as "will be removed" instead of "has been removed"?
My second question is, why is there no message like that when I run this code locally with Python 3.9.16? Is that because this message has only been implemented starting from a later version of arcpy?
