For others reading this item, the bug item Steven mentioned is listed below and currently under review:
IT re-imaged my box, a total wipe of the C drive, and re-installed all the software and now it is working. Ghost in the system are gone. Not sure the cause but it was a drastic step to fix it.
Hey,
Just FYI, I have been having the same issue and I put in a ticket to ESRI, they are apparently aware of this issue and have some workarounds.
They suggest installing Microsoft Access Database Engine, if that's not on the machine running pro, pro will sometimes fire those services off.
The second thing they suggested was if this was happening on a server environment and you are running scheduled python scripts or models to use the servers python environment instead of pro's.The Microsoft Access Database Engine is what solved my issue, but hope this helps you or anyone else facing this issue!
