Can someone advise I want to create a dashboard using future layers from the Survey123 URL but getting the message that the layers are not accessible. What to do?
Can you try:
The layer not accessible message is generally something you might see on Feature Collection:
https://support.esri.com/en-us/knowledge-base/problem-unable-to-access-feature-layers-in-arcgis-dashb-000023127
I wonder if you are using one of the default survey layers where querying is disabled. Using the steps above will give access and secure your data.
Thanks this was very useful advice and great support
i am getting above message
Thanks. Yes published, used connect , using AGC GIS online organisation
@DrJumaKhudonazarov Is the survey published yet? Are you using AGOL or enterprise? Did you create the survey on survey123 online or connect?
