Hi!
I am trying to use `dragEnabled` with the `LayerList` widget and three `FeatureLayers`, but I cannot reorder my layers. Could someone provide me with a functional example of how to use it?
Thank you.
Hi @Antonio_Fraga ,
If you are using the layer list component you can use the drag-enabled attribute like this:
<arcgis-layer-list drag-enabled position="top-right"></arcgis-layer-list>
https://codepen.io/sagewall/pen/raBNdxq
Or if you are using the widget you set the dragEnabled property to true like so:
const layerList = new LayerList({ dragEnabled: true, view: view });
https://codepen.io/sagewall/pen/vEBYRGN
Hope this helps 🙂
Hi @Sage_Wall ,
I just realized, thanks to your example, that it was referencing version 4.28 of the API. I updated it to 4.31, and it works perfectly.
Thank you!
@Antonio_Fraga
