The "Print Widget" in experience builder should offer the ability to set "defaults" for these output parameters:
- The Output Spatial Reference
Currently, when folks generate a print layout their maps are not accurately shown to "scale" because the layout is being converted to a Web Mercator SR. This could be easily avoided if you could just choose your own "default output SR."
- The Scale Bar "Units"
Currently, the scale bar units can only be adjusted between "metric" & "imperial" units, but you cannot specify an actual unit - such as "US Feet." Majority of our map layouts are best represented by a scalebar in "feet"- so it's inconvenient to need to change that via the "Advanced Printing Options."
Austin
