The Proper() Arcade function is a handy way to format street names that are stored in all caps. But it doesn't deal with ordinals correctly; e.g., returns "16Th" rather than "16th". There are a few different ways to handle this in Python but I don't know how to do it with Arcade. Any ideas? Thanks!
You also might find the number function useful to check if the first character is numeric. It returns NaN if the value you give it is not a number, then IsNan can be used to check it. Something along these lines should satisfy a lot of the issues you mention:
var words = split($feature.NAME, " ") var label = "" for (var i in words) label += iif(IsNan(number(words[0])), proper(words), lower(words)) + " " return label
Although it won't give you correct capitalization in all cases e.g. James Ii Street instead of James II Street or Virginia Avenue Sw instead of Virginia Avenue SW .
Ciara Rowland-Simms demo'd this in Video Link : 5618 . Check out around 49 min 30 sec through 51 minutes...
Thanks for the video link; that heads me in the right direction. However, it doesn't totally fix the problem. Her example explicitly lists out 1ST, 2ND, etc. rather than a regex or some Arcade equivalent to Python's isalpha, capitalize, or capwords methods that handle any ordinals. I wondered if it would work on two or more digit ordinals and I verified it doesn't with my own data. I thought maybe I made a typo when copying her function, but I even went back and watched the video again to see if any two-digit ordinal streets are visible: Yep, and indeed the case wasn't fixed in her own example (see "12Th" below). I laughed a little when she said, "I can write quite a simple expression to fix that." It's 10 times longer than the Python solution, which actually handles any ordinal! Surely there's a better way to do this with Arcade?
Sorry for being a bit insensitive above; I'm very appreciative of all the help I've received here on GeoNet. I am always trying to cobble together solutions with my limited knowledge of Python and now Arcade. I get exasperated with the transition occasionally. I imagine Ciara's expression would in fact work as intended with a tweak or two. But the bigger issue is that I suspect Arcade simply doesn't have methods equivalent to Python's for this problem (yet). That makes sense; Python's been around many years and Arcade is still pretty new. Seeing as Arcade is entirely under Esri's control, there are many map-specific issues that should be incorporated into Arcade. For instance, wouldn't it be nice if Proper() simply handled case properly including ordinals? Is there some reason that would be undesirable or unworkable? Thanks.
Hi Jeff,
Sorry to hear it wasn't quite what you were looking for. Unfortunately only realized after the video meetup that I had missed off a couple of cases ("1TH", "2TH", "3TH") from my list of ordinals! I believe adding those in should fix the street name issues.
Proper case has quite a specific meaning in Arcade in that it capitalizes the first letter. This means in cases such as
proper("[hello]")
Arcade will return [Hello], even though the first character is a square bracket. It moves on to the second character to make it proper case. By contrast, the capitalize function in Python will leave this lower case. If that is the behavior you are looking for, this can be done in Arcade by explicitly pulling out the first character with something along the lines of:
var words = split($feature.NAME, " ") var label = "" for (var i in words) label += upper(words[0]) + lower(right(words, count(words) - 1)) + " " return label
However, this will not handle special cases such as if you have a leading bracket or quote, or if you require upper case compass directions. Those would also not be handled by Python's capitalize function. Indeed the StackOverflow article you mentioned includes regex examples which are looking for a digit followed by th, st etc. to handle the ordinals special case. Unfortunately the capitalization of street names can be fiddly. Regex is certainly an option in Python, but it is important to remember that this is doing the same work, just in a single (although often less readable) line.
While it is true that the proper() function could internally look out for and have special behavior to handle these known cases, Arcade is used globally, and not all languages share the same set of special cases. A special case for one user may not work for another. Writing these longer expressions for specific cases can take a little getting used to, but ultimately is what you are doing even in Python via regex.
I hope that helps! Let me know if you have any more questions.
All the best,
Ciara
We have hyphenated street names (for example "SMITH-ENKE"). Thank you, @CiaraRowland-Simms and @JeffThomasILM, your scripts have helped me a lot! I've worked out handling the hyphenated streets. I hope this helps out others.
var dir = $feature.PRD + " " var type = Proper($feature.STS) var post = " " + $feature.POD var stn = $feature.STN if (!IsEmpty(stn)) { var words = Split(stn, " ") var hyphen = Split(stn, "-") var street = "" if (hyphen[0] != stn) { street += Proper(hyphen[0]) + "-" + Proper(hyphen[1]) + " "; return concatenate([dir, street, type, post]) } else { for (var i in words) if (Left(words[i], 2) == "MC") { street += upper(words[i][0]) + lower(words[i][1]) + upper(words[i][2]) + lower(right(words[i], count(words[i]) - 3)) + " "; } else { street += iif(IsNan(number(words[i][0])), proper(words[i]), lower(words[i])) + " "; } return concatenate([dir, street, type, post]) } } else { return ""; }
For what it's worth, here's another approach to finding and replacing those ordinals that come out of Proper()
var name = Proper($feature.STREET_NAME) for (var i = 0; i <= 9; i++) { var myNum = Text(i) name = Replace(name, myNum + "St", myNum + "st") name = Replace(name, myNum + "Nd", myNum + "nd") name = Replace(name, myNum + "Rd", myNum + "rd") name = Replace(name, myNum + "Th", myNum + "th") } return name
