Hi, I have a simple question. I've seen on the API reference that there's a HeatMapRenderer type for QML: HeatmapRenderer QML Type | ArcGIS for Developers
But I don't see any examples of this on the list. How does it work on Qt? Are there any examples of it available?
I've figured it out, here's the complete code for anyone in the same situation. I needed to create the renderer as a JSON, that was correct. But a FeatureLayer couldn't be set with this renderer. I needed to use a ServiceFeatureTable with a custom Feature Collection Layer, so I adapted the sample code that had it.
Here's the result:
import QtQuick 2.6
import QtQuick.Controls 2.2
import Esri.ArcGISRuntime 100.7
ApplicationWindow {
width: 800
height: 600
readonly property bool busy: featureTable.queryFeaturesStatus === Enums.TaskStatusInProgress
property var jsonChicago: {"type":"heatmap", "blurRadius":10, "colorStops":[
"ratio":0,
"color":[133,193,200,0]
"ratio":0.01,
"color":[133,193,200,255]
"ratio":0.0925,
"color":[156,129,132,255]
"ratio":0.17500000000000002,
"ratio":0.2575,
"color":[167,97,170,255]
"ratio":0.34,
"color":[175,73,128,255]
"ratio":0.42250000000000004,
"color":[184,48,85,255]
"ratio":0.505,
"color":[192,24,42,255]
"ratio":0.5875,
"color":[200,0,0,255]
"ratio":0.67,
"color":[211,51,0,255]
"ratio":0.7525000000000001,
"color":[222,102,0,255]
"ratio":0.8350000000000001,
"color":[233,153,0,255]
"ratio":0.9175000000000001,
"color":[244,204,0,255]
"ratio":1,
"color":[255,255,0,255]
], "maxPixelIntensity":1967.488043588503, "minPixelIntensity": 0 }
SimpleRenderer {
json :jsonChicago
Geodatabase {
path: pathName
onErrorChanged: errorMessage = error.message;
MapView {
anchors.fill: parent
Map {
BasemapStreetsVector {}
ServiceFeatureTable {
url: "https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/Chicago_Crime_Map/FeatureServer/0"
onQueryFeaturesStatusChanged: {
if (queryFeaturesStatus !== Enums.TaskStatusCompleted)
return;
var featureCollectionTable = ArcGISRuntimeEnvironment.createObject("FeatureCollectionTable", {featureSet: queryFeaturesResult,renderer:rendererT});
var featureCollection = ArcGISRuntimeEnvironment.createObject("FeatureCollection");
featureCollection.tables.append(featureCollectionTable);
featureCollectionLayer.featureCollection = featureCollection;
Component.onCompleted: {
queryFeatures(queryParams);
QueryParameters {
whereClause: "1=1"
FeatureCollectionLayer {
onFeatureCollectionChanged: {
map.operationalLayers.append(featureCollectionLayer);
BusyIndicator {
anchors.centerIn: parent
visible: busy
Hi there,
The type is creatable/usable, but as of writing only by setting the json on a Renderer. If you want to utilize the Heatmap, you could try one of these two ways:
Of these two approaches, the first option is probably better as AGOL comes with some nice authoring tools!
Kind regards,
Neil
Hi there Neil, thanks for the answer,
So, for a heatmap renderer, I would do something like this at the start? :
GraphicsOverlay
HeatMapRenderer
json: "json object here"
I haven't used json to create layer yet some I'm little lost on how they work.
Thanks.
Yeah, that doesnt work since I cant instantiate a HeatMapRenderer. I did try this:
property var jsonObject: {"type":"heatmap","blurRadius":10,"colorStops":[{"ratio":0,"color":[133,193,200,0]},{"ratio":0.01,"color":[133,193,200,0]}],"maxPixelIntensity":1249.2897582229123,"minPixelIntensity":0}
json: jsonObject
// Map view UI presentation at top
//! [Display Feature Service]
BasemapLightGrayCanvas {}
//initialViewpoint: vc
FeatureLayer {
renderer: renderer
url: "http://192.168.0.204:6080/arcgis/rest/services/geotecnia/gislmdc_uff_geotecnia/FeatureServer/4"
onLoadStatusChanged: {
console.log(layerName.renderer.rendererType.toString());
But I only get simple red points. I've tried instantiating a HeatmapRender by use of the
ArcGISRuntimeEnvironment.createObject method but to no avail, it's not creatable. If I get the Json, the renderer is a heatmap renderer but even then, I'm only show red points.
