I am using the code below to capture the XY coordinates when a user clicks on the map.
How can I adjust this for more significant digits?
Getting 36.25 I want 36.2545241
map = new Map("map", {
basemap: "topo",
center: [-78.728, 37.649],
zoom: 6
map.on("load", function() {
//after map loads, connect to listen to mouse move & drag events
map.on("click", showCoordinates2);
function showCoordinates2(evt) {
//the map is in web mercator but display coordinates in geographic (lat, long)
var mp = webMercatorUtils.webMercatorToGeographic(evt.mapPoint);
var XCoordMap= (mp.x.toFixed(3));
var YCoordMap = (mp.y.toFixed(3));
var XYCoordMap = (XCoord + ", " + YCoord);
document.getElementById("XCoord").value = (XCoordMap);
document.getElementById("YCoord").value = (YCoordMap);
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
