We have started having an issue with creating feature classes, running geoprocessing tools, and exporting data in the latest update. We work from a shared NAS drive and have not experienced this issue until a recent update.
We are running ArcGIS Pro 3.3.2
Windows 10
Buffalo NAS drive
I have tried this a couple of times and keep running into the same issue. Here are the steps:
1) Create a new project (using NAS folder)
2) create new feature class in project geodatabase
This is year I get a big red error box. When you close that you get a second message saying cannot acquire lock. Images attached.
However, if I refresh the file folder in the NAS drive and then refresh the geodatabase the created layer does show up and I can add it to the map.
Same issue with geoprocessing tools, for example "enable attachments" cannot acquire lock, but if I refresh the file folder then the geodatabase they are enabled.
Same with exporting the feature class. Incidentally I have also been getting an "001177: Attachments are not supported in this Geodatabase release." error but I think this is tied to the lock.
We have not experienced this before and have never seen this before using the same setup.
I read a post about it possibly being related to read-only access but we have read/write permissions. I have tested creating a new project on an external hard drive and do not have these issues.
From what I can tell this is either an internal network issue or a GIS issue. As this worked for us up until we installed ArcGIS Pro 3.3.2 I wanted to find out if this is an issue others are experiencing and if there is anyway to solve this.
