Please add the capability to copy tags as at times when you are publishing data from the same project, most of the tags stay the same. So having the option to copy them could save a bit of typing, cheers.
Hi @Ed_,
Thanks for your submission. There is a similar request on the use of existing tags here: https://community.esri.com/t5/arcgis-pro-ideas/select-tags-from-portal-when-publishing/idi-p/1089206
Would this meet your needs? Where are you trying to copy tags from and paste them to?
You may already be aware of this, but you can copy and paste tags to the Tags section in the Sharing pane. Multiple tags can be added or separated by a comma.
Also, you can set metadata at the data source or map. For more info, see https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/web-layer-metadata.htm
Best,
Jonah
1. Say i publish a project's feature class that has tags A, B, C.
2. then i publish another feature class from that same project so if i could have copied the tags in step 1 then i can just paste them in step 2 if that makes sense
Changing status to Open. This idea is about adding the ability to copy tags from the Tags section in the Share As Web Layer pane.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
