I think I've found a bug, but it's so obvious I can't be only person experiencing it. I have a WGS84 polygon layer stored in ArcGIS Online. When I add it to a web mercator map(3857) in ArcPro and try to create a new circular feature, the features initially show as circles then change to what looks like two circles merged together when the map is refreshed. No, it's not the geographic oval shape, my projection is set correctly. If I set my projection to WGS84, the data appears as circles, but they should look like ovals. If I look at the data in ArcGIS Online on a web mercator map it appears as geographic ovals, but should appear as circles. It's like it's handling the projections changes in reverse. And if I upload the same data as 3857 it all works fine.
Anyone else have this issue and is there a fix other than storing data in 3857?
