IMapDocument mapDocument = new MapDocumentClass(); mapDocument.Open("path to my document"); // at this point you might want to navigate to a desired location and scale ESRI.ArcGIS.Carto.IActiveView activeView = mapDocument.ActiveView; ESRI.ArcGIS.Geometry.IEnvelope zoomExtent = new ESRI.ArcGIS.Geometry.EnvelopeClass(); //possiblities are for example //zoomExtent.CenterAt(); //zoomExtent.Expand(); //zoomExtent.PutCoords(); activeView.Extent = zoomExtent; ESRI.ArcGIS.Output.IExport export = new ESRI.ArcGIS.Output.ExportPNGClass(); System.String pathFileName = "name of export png file"; export.ExportFileName = pathFileName; // Because we are exporting to a resolution that differs from screen // resolution, we should assign the two values to variables for use // in our sizing calculations System.Int32 screenResolution = 96; System.Int32 outputResolution = 300; export.Resolution = outputResolution; ESRI.ArcGIS.Display.tagRECT exportRECT; // This is a structure exportRECT.left = 0; exportRECT.top = 0; exportRECT.right = activeView.ExportFrame.right * (outputResolution / screenResolution); exportRECT.bottom = activeView.ExportFrame.bottom * (outputResolution / screenResolution); // Set up the PixelBounds envelope to match the exportRECT ESRI.ArcGIS.Geometry.IEnvelope envelope = new ESRI.ArcGIS.Geometry.EnvelopeClass(); envelope.PutCoords(exportRECT.left, exportRECT.top, exportRECT.right, exportRECT.bottom); export.PixelBounds = envelope; System.Int32 hDC = export.StartExporting(); activeView.Output(hDC, (System.Int16)export.Resolution, ref exportRECT, null, null); // Explicit Cast and 'ref' keyword needed export.FinishExporting(); export.Cleanup(); mapDocument.Close();
