Hello All,I have polygons in a geo-databases - WGS84I want to calculate the extent (XMin, ...)I have added a field XMin_Test (double)In the field calculator I added the Python expression !extent.XMin!I am getting the following error:ERROR 000539: Invalid field extent.XMinFailed to execute (Calculate Field).I have tried the field as text, changed the expression to !extent.shape.YMin!Same error.
Thanks.I am getting the same error.however when I use the expression: !test!extent.XMin It runs but no values are added to the field. All are NULL
Thanks,Below is the result:Executing (Add Field): AddField Geo_Index_All_test test DOUBLE # # # # NULLABLE NON_REQUIRED #Start Time: Mon May 20 12:00:04 2013Adding test to Geo_Index_All_test...Succeeded at Mon May 20 12:00:05 2013 (Elapsed Time: 1.00 seconds)Executing (Calculate Field): CalculateField Geo_Index_All_test test !TEST.Extent.XMin! PYTHON #Start Time: Mon May 20 12:00:05 2013ERROR 000539: Invalid field TEST.Extent.XMinFailed to execute (Calculate Field).Failed at Mon May 20 12:00:05 2013 (Elapsed Time: 0.00 seconds)However,Below are the results when with different expression (runs - but all NULL) Geo_Index_All_test test DOUBLE # # # # NULLABLE NON_REQUIRED #Start Time: Mon May 20 12:02:19 2013Adding test to Geo_Index_All_test...Succeeded at Mon May 20 12:02:20 2013 (Elapsed Time: 1.00 seconds)Executing (Calculate Field): CalculateField Geo_Index_All_test test !TEST!.Extent.XMin PYTHON #Start Time: Mon May 20 12:02:20 2013Succeeded at Mon May 20 12:03:22 2013 (Elapsed Time: 1 minutes 2 seconds)
Thanks a lot.The syntax that works in model builder is as follows:!SHAPE!.extent.yminObviously the shape field needs to be capitalized and surprisingly the xmin field need not be.
import arcpy import os from arcpy import env # Set the current work Space - the input feature folder arcpy.env.workspace = r'Y:\USGS_HiRes\Appended_Polygons_BK\Test_Join.gdb\Placemarks_Join' # Select the input feature inputFeature = r'Y:\USGS_HiRes\Appended_Polygons_BK\Test_Join.gdb\Placemarks_Join\Geo_Index_All_test' inputFilename = os.path.basename(inputFeature) print 'The input feature is ...' print inputFilename # Process: Add all 4 Fields arcpy.AddField_management(inputFeature, "X_Min", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(inputFeature, "Y_Min", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(inputFeature, "X_Max", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(inputFeature, "Y_Max", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") print '' addedFields = arcpy.ListFields(inputFeature) for addedFields in addedFields: print ("Fields-Present:{0}".format(addedFields.name)) #Process: Calculate all 4 Fields arcpy.CalculateField_management(inputFeature, "X_Min", "!SHAPE!.extent.XMin", "PYTHON_9.3", "") arcpy.CalculateField_management(inputFeature, "Y_Min", "!SHAPE!.extent.YMin", "PYTHON_9.3", "") arcpy.CalculateField_management(inputFeature, "X_Max", "!SHAPE!.extent.XMax", "PYTHON_9.3", "") arcpy.CalculateField_management(inputFeature, "Y_Max", "!SHAPE!.extent.YMax", "PYTHON_9.3", "")
