If the basemap projection dictates the web map projection, is there a way to take a map offline in a projection other than Web Mercator? I've sideloaded an raster tile .tpkx in State Plane which I would like to use onto my tablet, and my web map operational layer is in State Plane, as well. However, I'm stuck with the paradox of having to use a Esri basemap in Web Mercator or WGS84 to enable the 'Offline' setting in the web map item page, but then this causes an error in the 'Offline' section of the Field Maps (Enterprise) app because the web map layers are in different projections. Is there any way to side-step this initial requirement?
Specs:
Enterprise 10.9.1
iPad Pro - iOS 17.7
