We have a variety of datasets in our SDE that need fields auto-populated when a feature's created. My current implementation works fine for FeatureLayers because I can access the Table object when new map views are accessed. I work through all the FeatureLayers in the Map's TOC and subscribe them to events as needed. Unfortunately for StandaloneTables I can't directly subscribe them because they can't be converted to a Table object. Is there any way around this?
Any help is greatly appreciated. My current implementation is as follows:
Module1.cs:
protected static void OnActiveMapViewChangedEvent(ActiveMapViewChangedEventArgs args)
if (MapView.Active != null)
EditorExtension.UnregisterRowEvents();
foreach (FeatureLayer layer in MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>())
EditorExtension.RegisterLayerEvents(layer);
foreach(StandaloneTable standaloneTable in MapView.Active.Map.GetStandaloneTablesAsFlattenedList())
EditorExtension.RegisterStandaloneTableEvents(standaloneTable);
EditorExtension.cs:
public static void RegisterStandaloneTableEvents(StandaloneTable standaloneTable)
QueuedTask.Run(() =>
MapMember mapMember = standaloneTable as MapMember;
CIMStandardDataConnection cimDataConnection = mapMember.GetDataConnection() as CIMStandardDataConnection;
if (cimDataConnection.WorkspaceConnectionString.Contains("SDE.DEFAULT"))
_rowCreatedTokens.Add(RowCreatedEvent.Subscribe(OnRowCreatedEvent, standaloneTable)); // ERROR: cannot convert standalonetable to table
