<\/P>
Hallo Arc Hydro-gebruikers,<\/P>
Ik ben benieuwd of iemand regelmatig de Parallel Processing Settings<\/STRONG><\/A> in de Analysis Environmental Settings aanpast. Zo ja, heeft het enig verschil gemaakt in de snelheid<\/STRONG> en verminderde crashes<\/STRONG>?<\/P>Ik ben overgestapt op Arc Hydro in Arc Pro (v3.3.52636) nadat mijn afdeling eindelijk de overgang had gemaakt.<\/P>Ik heb 16GB op mijn machine, hoewel ESRI aanbeveelt<\/A> 32GB beschikbaar met 64 GB voor 1ptimaal7 gebruik. <\/P>Ik heb moeite gehad om Arc Hydro-processen die eerder werkten in Arc Pro weer aan de praat te krijgen. Na het wissen van de cache en het zo leeg mogelijk houden van het Temp-bestand, en het opnieuw opstarten, lijken sommige problemen verdwenen te zijn (voorlopig).<\/P>Mark<\/P>
Mark<\/P>
Mark,
As we move AH capabilities from ArcMap to Pro, we will tweak some of the tools and workflows (and drop tools and add some). Within Pro world as well based on new Pro capabilities or enough experience that a better workflow is more stable/productive. There are several points you are making in your notes.
Hope this helps.
Dean
Thanks for the detailed reply Dean. I'll take your words to heart and move forward.
Mark
Dean,
Thanks for the reply; really appreciate your response.
I am generally conversant in the ArcMap version of Arc Hydro (AH) and the ArcPro version seems to be nearly the same. I typically only work with the AH tools when a project comes up. The latest project is a redo of one I cut my teeth on about 10 years ago. Unfortunately the layers from that effort wouldn't load into the latest version of ArcMap.
I did have similar struggles with the AH in ArcMap, but maybe that was this low RAM issue that I was unaware of before now.
So far I have run into a few things in the AH Pro version that seem different and require additional steps:
I am asking my IT group if they could upgrade my RAM. In our organization (in the past at least) tailoring computers has been very hard to achieve.
One idea I had was to add the "bookkeeping" effort of dividing the larger watershed into smaller working parts then merge the hydrologically correct DEMs together and do the rest from that. I do realize I could still struggle due to low RAM issues. I've attached a snapshot of my rawdem properties so you can see the basic size of my data. We have defined subwatersheds that I could use to break this into smaller parts.
FYI - I've always used ModelBuilder to put the processing steps together. It would be good to know if making models of the process increases the memory use or cause any other issues verses simply using the toolbox tools. There is no toolbar now as far as I can tell other than three tools under the Arc Hydro ribbon. Since there are pre-made models (such as Basic Dendritic Processing), I assume using ModelBuilder a reasonable practice.
Let us know how how your transition evolves. In Arc Hydro, we do not do anything particular on parallel processing settings (we use whatever has been set at system/Pro level). 16GB of memory IS on the low end for any significant raster processing. Depending on the tools you use (some load the full raster into memory and some can process it in "chunks") you might "struggle". But in general, that should not be different between the Pro/AH versions (but could, if the core tools have been tweaked). If you see consistent "misbehavior" with particular AH tool, let us know, and we'll check.
