I am setting base height expression in ArcScene and I am trying to publish the SXD in web using ArcGIS Pro it throws error that "invalid expression", even though the SQL expression validator doesn't through error. Kindly let me know how to solve this issue. For your reference I am attaching the screenshot of the expression which I set in ArcScene.
Just to chime in on this and add to the 'I think it's a bug' pile.
Pro 2.01 / ArcGIS Enterprise 10.5.1
I've got a multipatch polygon that is exaggerated by 400:
And when I try to share the layer to my portal, I see the same error as reported above:
However, when I remove the exaggeration (back to 1, default) the error disappears:
It appears as though any amount of exaggeration causes the share web scene/share web layer tool to throw up 00236.
Rich
couldn't help but notice that the sliver of an error above the one you posted refers to an unsupported spatial reference... are these somehow linked? or was that for another scene?
Yes Vb script parser is used still it throwing error while publishing, please refer the attached screenshot.
Expression used : * 10
Since the expression was created using ArcScene, it must have used VBScript parser.
did you type that expression? or did you use the calculator to select the Z field, the multiply and the 10? I thought python was now used in Pro so I am surprised if the field isn't enclosed in double exclamation marks (ie !Z! * 10 )
