function flashFeature(graphic) { var text; if (graphic.geometry.type == "point") { var extent = graphic.geometry; text = "Point: " + graphic.geometry.x + ", " + graphic.geometry.y; } else if (graphic.geometry.type == "polyline") { var lineExtent = graphic.geometry.getExtent(); var extent = new Extent(lineExtent.xmin, lineExtent.ymin, lineExtent.xmax, lineExtent.ymax, new SpatialReference({ wkid:102100})); text = "Line: " + extent.xmin + ", " + extent.ymin + ", " + extent.xmax + ", " + extent.ymax; } if (!map.extent.contains(extent)) { console.log("Outside current extent - " + text); } else { console.log("Inside current extent - " + text); } map.graphics.add(graphic); }
var extent = map.extent; if(extent.contains(graphic.geometry)) { graphic.setSymbol(highlightSymbol); }
function flashFeature(graphic) { var text, extent; if (graphic.geometry.type == "point") { extent = graphic.geometry; text = "Point: " + graphic.geometry.x + ", " + graphic.geometry.y; } else if (graphic.geometry.type == "polyline") { extent = graphic.geometry.getExtent(); text = "Line: " + extent.xmin + ", " + extent.ymin + ", " + extent.xmax + ", " + extent.ymax; } if (!map.extent.contains(extent)) { console.log("Outside current extent - " + text); } else { console.log("Inside current extent - " + text); } map.graphics.add(graphic); }
