Hi
Is it possible to use a local TIFF, MXD or PDF file has a a basemap in a MapView? Or just add it has a layer? Or does it has to be absolutly a raster layer on a portal.
Thank you
Yes, I'm not sure about MXD or PDF but I work with TIF regularly.
Do note, to deploy a app with TIF you will need the standard runtime licensing pack to my knowledge. I am not sure if there is a good work around for this.
https://developers.arcgis.com/net/layers/add-raster-data/
Found this to add a Shapefile too! 🙂https://developers.arcgis.com/net/uwp/sample-code/feature-layer-shapefile/
