Also i just looked at this data. The x coordinates have 6 characters and the y coordinates have 7. Is this right? Shouldn't they both be 6?
The set up isPosition Frmt: UTM/UPSMap Datum: WGS84Unit: MetricNorth ref: GridVariance: 0,02 EAngle: DegreesI attached to you a file.txt with some pointYou said that UTM 30N coords York are the same value that I will find in France using the WGS 84 Web Mercator (Aux sphere) coordinate system. However when I introduce my value (gps point) in googe earth, there are location in York not in France. This is why I am too bewildered. Thanks you for your help
I do not have the cable to download the gps data (garmin etrex H) to the pcI need and aerial photograph of my place with high resolution. Is it free to access this information to ordnance survey?
Try running the data through a proper GPS convertor such as GPSBabel.http://www.gpsbabel.org/You might also want to look at alternative basemaps. How about converting the points to British National Grid and using OS Streetview?http://www.ordnancesurvey.co.uk/business-and-government/products/os-streetview.html
Hi,You said originally that the GPS was set to use UTM/UPS. Try setting the coordinate system of your XY data to WGS 1984 UTM zone 30N (north). UTM 30N coords near York are the same values that you would get in France using the WGS 1984 Web Mercator (Aux Sphere) coordinate system. This assumes that the coordinate values are around easting/x = 625000 m, northing/y = 5980000 m. (York Museum Gardens)If not, can you post a row from your spread sheet? Or copy a row or two, export it to text/csv and post that, if possible. Melita
Rafa,did you try and switch the X and the Y coordinates and see if that fixes the location?Tim
