We are approving Oracle 23 in our environment. I would like to know when this version will be supported in Enterprise and ArcGIS PRO. Can you give me an estimate?
If I use it without ESRI approval, will it not work?
Similar post: How long does it take Esri to support a new Oracle version?
The new released version of the Oracle Database is usually certified / supported on the next ArcGIS Release.But sometimes it can take Esri a little longer to certify the new Oracle Database Version.
@GustavoMartineli12 wrote:If I use it without ESRI approval, will it not work?
Even if you are able to use it, it won't be supported and can be unstable. So surely not worth the risk.
If you prefer, I recommend reaching out to Esri Tech Support for an official word on both.
Has Oracle 23c on-prem been released yet?
I had a similar question earlier and Esri recommended me to follow and check for updates here:
FAQ: What Oracle Database Versions Are Supported by ArcGIS Enterprise and ArcGIS Pro? (esri.com)
Fingers crossed 🤞🏻 that Oracle 23 will be supported soon.
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
Hopefully with ArcGIS Enterprise 11.4 which should become available soon (+update for 11.3)
You can find an update here: Re: How long does it take Esri to support a new Or... - Esri Community
