I have a feature class of polylines that are duplicate, one on top of the other and i would like to delete all except for 1 and it doesn't matter witch one just as long as there is one left. I would like this to be done in arcmap.
I have the following that identifies the duplicates but i am not sure on how to delete duplicates in the set.
import itertools, arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "Parcel_Lines1")[0]
dsc = arcpy.Describe(lyr)
sr = dsc.spatialReference
oid_field_name = dsc.oidFieldName
# get a cursor on the input features
rows1 = arcpy.SearchCursor(lyr)
# exclude features already compared once
exclude = []
# iterate through the first coursor
for row1 in rows1:
oid1 = row1.getValue(oid_field_name)
shp1 = row1.shape
# get a second cursor on the same input features
rows2 = arcpy.SearchCursor(lyr)
# add the feature to be compared to exclude list
exclude.append(oid1)
# create a set to hold duplicate features
group = set()
# iterate through the second cursor
for row2 in rows2:
oid2 = row2.getValue(oid_field_name)
shp2 = row2.shape
# ignore features already compared
if oid2 in exclude:
continue
# test equality
if shp1.equals(shp2):
# add both feature ids to the set of identical features
group.add(oid1)
group.add(oid2)
# add the feature just compared to the exclude list
exclude.append(oid2)
if group: # if the group is not empty
print group
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
