I'm curious if anyone else is experiencing this issue!
For the most part, we've had our entire organization on ArcGIS Pro since 2020. We had to move because deploying and installing Pro was SIGNIFICANTLY easier that ArcMap during the pandemic. I had already been installing it on some machines the year prior, but decided to just go for it because in it made it easier to manage.
It took a second to figure out (I still have to Google stuff sometimes) - but all in all, everyone was really happy with the switch. We had to redo some processes, but it was for the better. Since 2021, I've only had 1 occasion where I needed to install ArcMap for a small research group - and it was only because they were doing a research project with a government entity that was using an ArcToolbox that was not compatible yet with Pro. But that has only been once since 2021 that we needed ArcMap.
But with some new incoming users experienced with ESRI software - I've had multiple people mention that they are reluctant to switch to ArcGIS Pro because they hear that it REQUIRES a coding background in order to use the software.
I also have very minimal background in coding - but I've had 0 issues with ArcGIS Pro! Typically, I'll work with the user to show them how to duplicate their process in Pro. That usually helps to convince them to make the switch. But it's come up multiple times that their specific reason is "they hear it requires code to work".
Yes, coding helps and can automate things, but it makes it less accessible to the general public. It's a little frustrating that it's the impression some users are getting, and it's causing a lot of stress for some making the switch, so I feel a little bad about that.
Anywho! That's just my two cents. Curious if anyone else has run into this problem a well and how they've dealt with it.
