Good morning,
I do have two feature classes I want to show on a list. Should I create 2 lists, or is there a way to add both lists and add a tab to switch between one list to the other.
Hi @SanchezNuñez ,
The list widget cannot connect two data sources.
For your case, I would suggest using Section and Views navigation widgets. You can add two views to the section and a list widget to each view.
Regards,
Shengdi
Thank you @ShengdiZhang for your recommendation, I am going to try that.
