Using the QuickCapture Photo Inspection template I have collected a couple of locations with photos. I am attempting to view them using the Sidebar styled Instant App as a proof of concept. Upon adding the map to the Instant App, I am unable to toggle on the oriented imagery slider because it is not enabled. Why can't I enable oriented imagery for my Instant App? I am able to view the images through the map viewer using the oblique imagery viewer.
Are you able to use the Oriented Imagery Viewer in the ArcGIS Online Map Viewer using the same web map you are viewing in the Sidebar configuration?
https://doc.arcgis.com/en/arcgis-online/create-maps/work-with-oriented-imagery-layers-mv.htm
I ran a quick test using a web map with an oriented imagery layer and was able to successfully enable the oriented imagery tool in Sidebar. Here's an example:
https://jsapi.maps.arcgis.com/apps/instant/sidebar/index.html?appid=79ac4af851f347b7970cc311f918ec43
Thanks for your feedback. The photo inspection Quick Capture template creates a lot of content. The webmap created doesn't reference the correct hosted feature layer. I had to use a different one in a newly created map and reference it when configuring my Instant App.
