File geodatabases are downloading from our ArcGIS Hub website with .gdb file extension instead of the .zip extension. The downloaded files are zip files. Replacing the .gdb extension with .zip allows the FGDB to be extracted. Is anyone else experiencing this problem? Daniel Fenton can you look into this?
Our website is https://gisdata-piercecowa.opendata.arcgis.com/.
Thanks!
You should not change the extension of the filegeodatabase to .zip.
Rather you should use a zip utility like Winzip or PKUNZIP to zip it up.
Windows thinks the database is a folder
We are hosting our data on ArcGIS HUB/Open Data. The problem was introduced in the past two weeks. File Geodatabases were downloading as .zip files. FDGBs are now downloaded as .gdb files, and not recognized by ArcMap or ArcCatalog. ESRI controls the download file extension type. Try downloading one of our FGDBs, and you will see the problem.
We're on it. Should have a fix out tomorrow. We apologize for the regression.
Daniel Fenton
Thanks Daniel!
Daniel,
File geodatabases are downing with the correct zip extensions, but we are experiencing problems with the FDGB downloads.
Some FGDBs never download. Their download status does not change from Gathering Data. We have seen this for recently updated data, and data not updated for years. Examples are:
Permits (updated 3/20/2019 😞 http://gisdata-piercecowa.opendata.arcgis.com/datasets/4e7d077f18e845a0b9525847ec7db403_0
2010 Census Tracts (2015) http://gisdata-piercecowa.opendata.arcgis.com/datasets/1502ded791fe408d8bc031ac9f63a361_0
Some FGDBs are downloading fine. But their feature counts indicate that the data is an old version. Corresponding shapefiles’ feature counts are correct. An example is Address Points (updated 3/21/2019).
Address Points: https://gisdata-piercecowa.opendata.arcgis.com/datasets/f47f07cb865244fd805760d7542678b6_0
2010 Census Tracks: http://gisdata-piercecowa.opendata.arcgis.com/datasets/1502ded791fe408d8bc031ac9f63a361_0
FGDB download links have disappeared. We saw this with data added this afternoon. It is our Puget Sound generalized data.
http://gisdata-piercecowa.opendata.arcgis.com/datasets/b41ee50f393942fa8d757221d609e2b6_0
Can you verify this problem and fix it?
Cort
This issue has now been resolved. Let us know if you see any further issues.
We see additional issues. When we update hosted feature layers only the shapefile download shows the updates. The FGDB downloads continue to download the old data.
For example, our zip code data was updated on April 1st, and the FGDB still shows the old data on April 4th.
Zip Code Data; http://gisdata-piercecowa.opendata.arcgis.com/datasets/zip-codes
Hi Cort -
The outdated FGDB download issue is now resolved. Thanks very much for noting this on GeoNet. Please reach out if you experience further issues.
Rich Gwozdz
Rich,
We still see data discrepancies. Have the code changes been pushed to the entire system?
The zip code FGDB contained old data this morning when it was downloaded around 7:15 am. We ran an update and at 7:40 am there is still no change.
Other data was updated this morning. It was checked around 7:00 am.
Address Points Updated at 4:41 am (point data)URL: https://gisdata-piercecowa.opendata.arcgis.com/datasets/address-pointsIn house count: 387654387695 shp old count387695 fgdb387695 csv387,654 Website new count
Roads Updated at 6:02 am (line data)URL: https://gisdata-piercecowa.opendata.arcgis.com/datasets/roadsIn house count: 5099250992 shp50991 fgdb50992 fgdb 2nd time downloaded50992 csv50,992 Website
Permits Updated at 6:36am (point data)URL: https://gisdata-piercecowa.opendata.arcgis.com/datasets/permits-pierce-countyIn house count: 635639635238 shp635238 fgdb635573 csv635,572 website
Thanks for reaching out again. At least part of what your are experiencing may come from the delay in generating a fresh FGDB. In an effort to deliver downloads quickly, the Opendata website follows the following flow when a file is requested for download:
1. Check to see if the file is already available for download
2. If file is available, check to see if the file is out-of-date relative to its hosted feature service; if it is outdate, begin generating a new file with the latest data. Note that this can take several minutes to hours depending on the size of the dataset.
3. Deliver the existing file, even if it is out of date, so that the user avoids long wait times for large downloads. The fresh FGDB overwrites the out of date file as soon as it is available. All downloads from that point on will use the fresh FGDB.
So in the case of larger downloads, the updated dataset may not be able to be downloaded for 10's of minutes to hours.
As of this writing, I find that downloaded FGDBs for your "Address Points", "Roads", and "Permits" have record counts that match what you noted for the website count (and the hosted service API). So I think the discrepancy you reported above for these datasets was due to the new FGDB files not yet being completely generated; as such you were receiving the file on hand, which was out of date.
Regarding permits, I notice in your message that your in-house count doesn't match the number on the website. It looks as though your in house data for Permits was not published properly. The hosted service has a last edit date of Monday, April 15, 2019 6:32:33.723 PST. That would explain the difference between your in-house count and website count.
Regarding Zipcodes, can you describe the changes you were expecting to see in the FGDB download?
Hi Rich,
Thanks for explaining the update process on your side. We can write a process to trigger the data download to general fresh FGDB, shapefiles, and csv files. The problem for our users is that not all data and references to the data are updated at the same time.
The Address points overview tab shows 387,654 records and the date is 4/16/2019. This is the same date the data update was run. The number of records matches the new data. When a user downloads the data as a shapefile, csv, and fgdb the records counts are all 387,695. This the old record count. The end user is left guessing if they have the most current data. Since the refresh time is not consistent, we cannot tell them exactly when the new data will be available for download.
The Roads data was updated 1 1/2 hours after the address data. After the FGDB was downloaded once, all references to the data record count were consistent. Are there better times to update data?
The permit data is updated an hour before it is updated in Open Data. The mxd has a field turned off that is not useful to anyone outside our agency. It is possible one of these things caused the data not to publish properly. We will look into changing process times and removing the field in another way. Is there a way to script a check that it did not publish properly?
The zip code change we expected to see in the FGDB are in the above screen shots. I downloaded the FGDB recently, and it does not show the boundary change. The shapefile does show the change.
Cort -
Let's take these one at a time and see if we can figure out what's happening. When I visit the Address Points page (Address Points) right now and download the fgdb (https://opendata.arcgis.com/datasets/1501552c77d5462ea141c9bf68584f16_0.gdb?outSR=%7B%22latestWkid%22%3A2927%2C%22wkid%2…), I receive a FGDB, which when opened displays 387,654 records. That seems to be what you're expecting. Can you confirm you get a different record count with a freshly triggered download?
I just downloaded the Address points data (fgdb, shapefile, and csv).
The counts were:
FDGB: 387695
Shp: 387695
csv: 387695
Then I downloaded the same files using Chrome's Incognito window. All three have the current data, 387,654.
This may be a browser issue. The problem is that if I am having this problem, then others will have it too. We had a similar issue with websites we wrote years ago. The solution was to append a cache buster GUID to the URL string. The browser would then see the page as new and refresh it.
Can you confirm this solves your issue with ZipCodes? I'm not familiar enough with the zipcodes of Pierce County for your screen capture to aid me examining the downloaded data.
Regarding publishing problems with your MXD, I would post a new GeoNet issue specifically for that so that you can get the proper expertise - it's not specific to ArcGIS Hub.
Either going incognito solved the zip code problem or it finally update in Open Data.
