<configuration label="Calculate Areas"> <taskurl>http://SERVER/ArcGIS/rest/services/GP/viewer/GPServer/Calculate_Acres</taskurl> <layerorder></layerorder> </configuration>
What I'm trying to acheive is a way of automatically updating a field once a layer has been created or modified. Specifically, when a user creates a polygon (using the Edit widget) I want a field called "area_ac" to automatically populate with the area of that polygon in acres.Is there a way of doing this?I figured that a manual way of updating the "area_ac" field would be to create a very simple Geoprocessing service that uses the Calculate Field tool, and then use the Geoprocessing widget to run it.I tried setting up an xml config for the Geoprocessing widget, but I don't think it likes the fact that there are no inputs or outputs associated with the service. When I press the submit button on the widget I get an error:ProblemesriJobFailedFailed.Is it possible to run the Geoprocessing widget without inputs or outputs?GeoprocessingWidget_CalculateAreas.xml<configuration label="Calculate Areas"> <taskurl>http://SERVER/ArcGIS/rest/services/GP/viewer/GPServer/Calculate_Acres</taskurl> <layerorder></layerorder> </configuration>
