Hey y'all,
If this has been answered before I would be much obliged if somebody would send me the link, as I have been unable to find it.
Anywho, I'm encountering an issue regarding the popup window for coordinates in drone2map. That is, when I open the window to change the desired image/output coordinate systems, I am met with a tiny, non-resizable window that does not suitably display the proper functions.
This is a recurring issue that will go away, though I have been unable to recreate the instances that produce or remedy it.
I have tried 3 different displays now, multiple resolutions, and multiple Windows scales, but the popup does not change in size, leading me to believe this is an issue with Drone2Map, but I am uncertain. Interestingly, the popup was a functioning size earlier this day when I processed another project, but now it refuses to cooperate.
See below for the image of what I am referring to. I don't know why this popup wouldn't be scalable in the first place, but that's beyond me. Hopefully this is an easy fix on my side and not some sort of bug.
Thanks in advance.
