As of the release of the API 4.12 we have a problem with the Measuring tools. When instantiating the tools with the unit property set to "meters" or "square-meters", the tools won't initialize and report the following error:
Cannot read property 'coordsys' of null
at Function.b.DX (geometryEngine.js:1155)
at Function.b.vR (geometryEngine.js:1149)
at g.Ao (geometryEngine.js:1149)
at Function.d._getTransformation (geometryEngine.js:1280)
at p (projection.js:4)
at k (projection.js:4)
at Object.b.project (projection.js:5)
at Object.a._updatePolylines (DistanceMeasurement2DTool.js:14)
at Object.<anonymous> (DistanceMeasurement2DTool.js:6)
at f (dojo.js:386)
This is also the case with other units. Only "metric" works for me (haven't tried imperial).
You can try it in de sample at: https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=widgets-measurement-2d
activeWidget = new DistanceMeasurement2D({
view: view,
unit: "meters"
doesn't work.
view: view,
unit: "metric"
works, so I use that now.
Is this a bug introduced in 4.12? In 4.11 we had no problems.
