When I load a web scene from Arcgis Enterprise I get the error. When I load a web scene from Arcgis Online it does not give the same result and loads the map or scene.
4.30
Hello @emreaktas1 The error you mentioned is usually due to one of the following reasons:
// Set the hostname to the on-premise portal esriConfig.portalUrl = "https://myHostName.domainName.com/webadaptorName"; const webScene = new WebScene({ portalItem: { // Here your item id id: "xxxxxxxxxxxxxxxxx" } });
I hope this can help you. Otherwise, please attach your code here (or send it to me privately) so I can investigate further.
this solved the problem. thank you @MatteoRizzi1
