Hi,Agreed, Make Image Server Layer should do the trick. It returns a Raster Layer which you can add to ArcGIS Explorer. First of all you can create the service then use the OOTB "Analysis Gallery" in ArcGIS Explorer to consume the service. From there you can write a custom Add-in if you like to provide an alternative, tailored UI for your workflow.RegardsMike
Hi,I don't believe you need to use a GP service to do this - you should just be able to use the Image Service itself (but in the same way you were probably expecting to need to write a GP Service). You would pass the raster ID into the Mosaic Rule parameter of the Export Image request which would create a raster dataset from which you then create a local RasterLayer. - Example Image Service: http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/World/Temperature/ImageServer/exportImage?bbox=-180,-55.5,180,83.5- REST API Help (for info): http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/index.html?exportimage.html- For an example SOAP WSDL see http://sampleserver3.arcgisonline.com/ArcGIS/services/World/Temperature/ImageServer?wsdlIf you're writing a .NET Add-in for Explorer then the ArcGIS Server SOAP API is probably going to be the easiest to use but you could use the REST API if you are that way inclined. Here's an example from the SOAP API Help (http://help.arcgis.com/en/arcgisserver/10.0/apis/soap/SOAP_CSharp_Examples.htm#ExportImage):ExportImage//define image serverstring url_DEMService = "http://ais3/arcgis/services/testDEM/ImageServer";testDTED_ImageServer imageSrv = new testDTED_ImageServer();imageSrv.Url = url_DEMService;//define image descriptionGeoImageDescription geoImgDesc = new GeoImageDescription();geoImgDesc.Height = 600;geoImgDesc.Width = 800;geoImgDesc.Interpolation = rstResamplingTypes.RSP_BilinearInterpolation;ImageServiceInfo isInfo = imageSrv.GetServiceInfo();geoImgDesc.Extent = isInfo.Extent;//define a hillshade function and attach to a rendering ruleRenderingRule renderRule = new RenderingRule();HillshadeFunction function = new HillshadeFunction();HillshadeFunctionArguments argument = new HillshadeFunctionArguments();argument.Names = new string[] { "Altitude", "Azimuth", "ZFactor" };argument.Values = new object[] { 45, 315, 1.0 };renderRule.Arguments = argument;renderRule.Function = function;renderRule.VariableName = "DEM";geoImgDesc.RenderingRule = renderRule;//define export formatImageType imageType = new ImageType();imageType.ImageFormat = esriImageFormat.esriImageJPG;imageType.ImageReturnType = esriImageReturnType.esriImageReturnURL;ImageResult result = imageSrv.ExportImage(geoImgDesc, imageType);//download resultstring fileName = @c:\temp\hillshadeFunction.jpg;System.Net.WebClient webClient = new System.Net.WebClient();webClient.DownloadFile(result.ImageURL, fileName);RegardsMike
Hi,Unfortunately there is no access to Image Service properties via the API in the current release. I you would like to see this added in future please submit the idea at http://ideas.arcgis.com RegardsMike
