I am not an expert by any means. What I want to do in Arcade is use the Association (containment) table. Writing Arcade statement on a versioned combining spatial/non-spatial features. I want to use this same pattern of these 2 joins into a line feature table that is non-versioned for several different spatial features in Utility Network.
1. Based on the functionality of the Join GP tool in ArcGIS Pro: Input table: Electric Edge Objects; Input Join Field-GlobalID; Join Table-Associations ;Transfer Method-Select Transfer Fields; Transfer Fields-FromGlobalID
2. Based on functionality of the Join Feature GP tool in ArcGIS Pro: Target Layer-Structure Line; Join Layer-Electric Edge Object; Output Dataset- Structure Line_JoinFeatures; Join Operation-Join one to many; Target Field-GlobalID, Join Field-FromGlobalID
3. Output as a line feature table that non-versioned
So basically I used the export associations GP tool in ArcGIS Pro. I then added the export associations file as table in my test Filegdb in a UN. I then wanted to join the ElectricEdgeObjects to the Associations (Containment) table using step 1 as my inputs. I then used the ElectricEdgeObjects and joined to the Structure Line spatial UN feature based on using step 2 as my inputs. I then want to output this joined feature to line feature class table that is non-versioned.
Thanks!
Jeff
