Seems really simple, but quite strange it's not there (unless you frame a map in an app)
Select features tool, please - then couple with an export to tool would be epic.
Selection is on our roadmap in Map Viewer. With how selection will work between map selection, table selection, chart selection and more we needed to have a way where things could communicate the selection across these components that would work well with small and large selections.
@RussRoberts thank you for the response - appreciate it's not quite as simple in coding reality. (also, please, please, please give us ISO 8601 dates, please) 🙂
We support those with an update last fall. Using the new timestamp offset field depending on how the time zone is configured in the map view will change the display of them but you can also configure this with arcade as well.
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/working-with-time-zones-in-map-viewer/
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/time-is-on-your-side-with-new-field-types-in-arcgis-online/#TSO
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
