The problem is that when the bitmap is the entire map there is a lag in generating the bitmap.If the bitmap is a smaller area the lag is unnoticeable.This a bug we are fixing.The code posted earlier if executed twice works without a problem.Try using the code below, if you single tap on the map twice you will see the bitmap. map.setOnSingleTapListener(new OnSingleTapListener() { /** * */ private static final long serialVersionUID = 1L; public void onSingleTap(float arg0, float arg1) { Polygon polygon = map.getExtent(); Envelope env = new Envelope(); polygon.queryEnvelope(env); Bitmap bitmap = map.getDrawingMapCache(arg0, arg1, 100, 100));// Bitmap bitmap = map.getDrawingMapCache(0, 0,// map.getWidth(), map.getHeight())); Log.d(TAG, "width = " + map.getWidth() + " ht = " + map.getHeight()); ImageView img = new ImageView(HelloWorld.this); img.setImageBitmap(bitmap); map.addView(img); } });ThanksArchana
map.getDrawingMapCache(0f, 0f,mMapView.getWidth(), mMapView.getHeight()));
Simon,I've tried setting it to false after generating the map image, and i've tried calling destroyDrawingCache() and getDrawingCache().recycle();. None of them seem to solve the problem.-Andrew
Just an update. We logged a bug for this behavior. NIM084361: MapView gets unresponsive after calling the getDrawingMapCache() method. We will target a fix in the upcoming release.Would you please comment on what you plan to do with the static image following the getDrawingMapCache() call? If we have a understanding of this we could test this method in the SDK accordingly.-Doug C, ESRI Support Services, SDK Tech Leadhttp://support.esri.com/
