Since updating to v4.9, i have had issues in IE 11 with updating the map property of the MapView. It may work on the first update, but then the second change would error out.
I have addressed a similar use case in a previous question (related to the LayerList widget at that time): [JS API 4.x] SPA with multiple map configurations .
There is a sample from Esri in which one can re-pro this issue (in IE 11 that is): Swap web maps in the same view | ArcGIS API for JavaScript 4.9
Does anyone know if there is any workaround to this issue, or would I have to go back to 4.7/4.8?
Regards,
Sebastian
