How do I go about permanently deleting an enterprise sde gdb. I know that you can right click and delete in ArcCatalog but that just deletes your connection to the gdb. But how do I permanently delete the gdb.
It depends on what enterprise database it is. I use sql server and have to go into sql server management studio to delete the actual database once i have removed the connection in ArcCatalog.
What version of ArcGIS? In which RDBMS? How many data owners? What storage types are used?
- V
Anthony/Vince
Thanks guys. Yea I probably should have been a little more specific. It is sql and we are running 10.1
Have a look at this microsoft help:
http://msdn.microsoft.com/en-us/library/ms177419(v=sql.105).aspx
Anthony
Thanks for the link. I went into sql server management studio and found the databases. Thanks.
If you want to delete anything short of the entire database you need to be careful to delete the SDE user in addition to any user tables using SDE-set rowids, versioning, archiving, and SDEBINARY geometry. In Oracle you can corrupt the entire instance by dropping the SDE user before dropping all tables which use SDE.ST_GEOMETRY storage (or ST_RASTER, I imagine). SQL-Server is the only RDBMS that does not support SDE.ST_GEOMETRY, so it's the safest for this kind or removal.
Vince
Thanks for the detailed response. The SDE gdb that I deleted was not in use by anybody or being used I created it but never put it to wide range use.
