I have a little problem with display TileXYZ layer at Webmap (AGOL). I can add it to the map, but it's not displayed. It looks like proxy problem - /sharing/proxy?. When application/map uses a proxy to display tiles, they are blocked (HTTP 500 code).
Link to the tile from the website:
https://katomapa.maps.arcgis.com/sharing/proxy?https://sip.katowice.eu/Data/o2023/RGB/16/36227/22154.jpg
Without a proxy it works fine:
Applications created with Experience Builder use proxy, so TileXYZ layer is not displayed, WMTS layer is displayed fine:
https://experience.arcgis.com/experience/3018263eb4ed42a48a21462f83e4d7fb/?draft=true
Application created with WebAppBuilder doesn't use proxy and everything is fine:
https://katomapa.maps.arcgis.com/apps/webappviewer/index.html?id=da8182bf107a47ae8a67d9604306c854
but it seems to not support WMTS layer 😉
Both application use the same map with two raster layer: WMTS and TileXYZ
How can I display this correctly on one map/app?
Thanks in advance
Damian
