Hi All,
Is anyone aware of an offline or how-to install for installing Story Maps on a closed network?
Thanks.
Chris
Do you mean install a story map so that it can be accessed by users just inside an enterprise and not by the general public?
Rupert - Sorry for the late reply on this.
I'm mainly interested in other Story Maps (such as MapJournal) that are available to be deployed within Portal. I'm in a dev environment with no Internet access so I'd like to deploy other Story Maps that don't rely on outside resources. I've successfully been able to do this with MapJournal.
I'm running 10.2.2 with the 3.9 version of the ArcGIS JS API so if such Story Maps exist, they would have to be compatible with those versions.
A Lot of the templates can be found on esri's github page:
Esri · GitHub
I'm familiar with the Story Maps on GitHub.
I believe only certain Story Maps will work offline (such as MapJournal). I'd like to know which ones work offline and/or if there is a compatibility matrix indicating required ArcGIS JS API, Story Map Version, and Portal Version for each Story Map to function properly.
Thanks!
