There is GetGraphic() method and GetGraphic().Symbol for the GraphicElement, but how to change the fill color?
This is a graphicelement drawn on a graphicslayer using the Graphics tab on the ArcPro UI...
https://community.esri.com/t5/arcgis-pro-sdk-questions/trying-to-change-the-fill-color-of-a/m-p/1514160#M11930
CIMSymbol SetColor : https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic16566.html
CIMPolygonSymbol SetOutlineColor : https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic16567.html
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic16566.html is invalid link...
Have following: but
CIMPolygonGraphic polygonGraphic = aoi.GetGraphic() as CIMPolygonGraphic;
// Access the symbol of the polygon graphicvar symbol = polygonGraphic.Symbol;
// Change the fill color of the symbol using SetColorif (symbol is CIMPolygonSymbol polygonSymbol){var solidFill = polygonSymbol.SymbolLayers.OfType<CIMSolidFill>().FirstOrDefault();if (solidFill != null){solidFill.SetColor(ColorFactory.Instance.RedRGB);}}
// Update the symbol in the graphicpolygonGraphic.Symbol = symbol;
Gives following errors:Severity Code Description Project File Line Suppression StateError CS8121 An expression of type 'CIMSymbolReference' cannot be handled by a pattern of type 'CIMPolygonSymbol'. EGIS.Core.Pro.Common C:\Users\EMSMP\Desktop\desktemp\repos\egis-Core-Pro-Common\Common\Data\MapProjectService.cs 185 ActiveSeverity Code Description Project File Line Suppression StateError CS1929 'CIMSolidFill' does not contain a definition for 'SetColor' and the best extension method overload 'SymbolExtensionMethods.SetColor(CIMSymbol, CIMColor)' requires a receiver of type 'ArcGIS.Core.CIM.CIMSymbol' EGIS.Core.Pro.Common C:\Users\EMSMP\Desktop\desktemp\repos\egis-Core-Pro-Common\Common\Data\MapProjectService.cs 190 Active
Change the color on the symbol, not the fill.
if (symbol is CIMPolygonSymbol polygonSymbol) polygonSymbol.SetColor(....)
To change the color on a fill, use its color property.
var solidFill = polygonSymbol.SymbolLayers.OfType<CIMSolidFill>().FirstOrDefault(); solidFill?.Color = .... ;
"Symbol" take a symbol reference not a symbol. An unfortunate property naming.
//polygonGraphic.Symbol = symbol; polygonGraphic.Symbol = symbol.MakeSymbolReference();
