Good morning,
I need to populate a test field Folio, with the folio number of the nearest property.
Can I do that with Survey123 or do I need to do it with Survey123 Connect?
Survey123 Connect is the program that is used to create forms to be used in the Survey123 app.
I think you should be able to do what you're looking to using a pulldata() expression in a form you create.
