Good afternoon
in EB or a Web Map, Is there a way to show a record count when showing a layer that draws by categories and also how to refresh this count.
@SanchezNuñez You can use either to show. In Web map you can use arcade. In experience builder you can add a text widget and then add dynamic content.For Experience builder:Click the Add data button and select "Query". Configure the query to return the number of records. You might use a SQL expression like SELECT COUNT(*) FROM <layer>.
